How to remove the steering column on a 1965 Ford Mustang Convertible? - Mustang Evolution
Old 08-23-2009, 08:15 AM   #1
how to remove the steering column on a 1965 Ford Mustang Convertible?
giyn21 is offline   Reply With Quote
Old 08-23-2009, 09:08 AM   #2
disconnect the linkage at the steering box,
disconnect the mounts under the dash,
disconnect all electrical connections,
pull
hamdi is offline   Reply With Quote
Old 08-23-2009, 09:50 AM   #3
what magz said its right
aswynn95 is offline   Reply With Quote
Old 08-23-2009, 10:27 AM   #4
magley has the right answer, but I'm a firefighter and we have 'other' ways of removing steering columns, but unfortunitely there won't be much left of your car LOL.
Don't be afraid to do as magley says, just be sure to remember how you take it out, it will have to go back in the oposite way. Good luck,
armond is offline   Reply With Quote
Old 08-23-2009, 10:32 AM   #5
Remove the 2 nuts at the bottom of the column, disconnect the electrical plug and pull the outer steering cover off. if you want the entire unit out unbolt the steering box 3 bolts
lucan is offline   Reply With Quote
Old 08-23-2009, 11:16 AM   #6
Also don't forget to disconnect the battery before you start.
westin is offline   Reply With Quote
Old 08-23-2009, 12:02 PM   #7
Go to the auto parts store and buy a Chilton or Haynes manual for your car. It'll give you the steps and the tools to do it right plus anything else you could want to do to your car.
jonni is offline   Reply With Quote
11:54 AM
