I have a 1975 Mustang II that vibrates a little.? - Mustang Evolution
Old 08-23-2009, 11:45 AM   #1
If it is u-joint, how expensive is that to fix at a garage/shop? The car is a 4 cylinder automatic.
dumont75 is offline   Reply With Quote
Old 08-23-2009, 12:22 PM   #2
So far everyone has got a little good info for you...
Would need to test drive it and/or get it up in the air to narrow down the problem...
If its the U-Joint on the driveshaft you might can hear it ping when you put it into gear also....
But vibration on a 75 model MII could be many things Front or rear... Tires, brakes, steering, drive shaft rearend etc... get someone to look at it with you... If you have a machanic friend try to get them to come over and look at it with you to see if it OK to drive or if it needs towed in.. If its a lite vibration take it to him or her....
Drive Safe.... Good Question....
archibald is offline   Reply With Quote
Old 08-23-2009, 01:07 PM   #3
can get both replaced under $100.
derik is offline   Reply With Quote
Old 08-23-2009, 01:34 PM   #4
that old diehard the drive shatf will make a sqweeking noise. if needs new u joints very cheap to fix and worth it have the tires checked one may beout of ballance or broke belt in tire itself. good old car .very dependable engine .
thornton is offline   Reply With Quote
Old 08-23-2009, 02:23 PM   #5
u joints are cheap by comparison but a vibration can be caused by a lot of things such as a bad tire
birtingr is offline   Reply With Quote
Old 08-23-2009, 02:34 PM   #6
the vibration can be cause from alot of different thing u need to find out whats causin it
nels91 is offline   Reply With Quote
1975 mustang
02:39 PM
