Gas pedal locked up? - Mustang Evolution
Old 08-24-2009, 04:15 AM   #1
ok i was driving and all of a sudden i notices it was going 40mph and i wasn't pressing the gas pedal. so i pulled it over and turned it off and i tried to press down the gas pedal and it wouldn't move i didn't press it super hard cus i didn't want to break it. i opened the hood and i could still move the thang that is hooked up to the gas pedal sorry i don't know what its called. its a 1976 mustang cobra II with a 3.0 v8 (i think..lol)
thanks.
booth is offline   Reply With Quote
Old 08-24-2009, 05:12 AM   #2
Two possibilities, -- one is that the "throttle cable" - which is several strands of wire has "shredded out" inside the cable shield, and jammed!
The other is that you don't have good ground from engine (or minus of battery) to frame. And cable was good enough ground (that power was flowing through it to ground), -- however if current gets high enough (and possibly several strands of cable broken alredy),- you had enough curent flow to heat the cable up "cherry red" and melt into the shield and now it will not move!
Since electricity (power + amps) will flow through the easiest path,--- and if body not grounded to battery -- it will not have normal "provided path" available -- so it will find another!
Even if the cable is broken --the remedy is the same, -- put in new throttle cable! Just make sure and check grounding (to make sure it is not that ), so it won't happen again!
lorren is offline   Reply With Quote
Old 08-24-2009, 05:58 AM   #3
you need to check the cable that is attached to the pedal and see if it is caught up on somthing or got kinked that the only thing i can think of right off hand
albion is offline   Reply With Quote
06:23 AM
