What is the order of operations to change the head gasket on a v8 1975 ford mustang 4.6? - Mustang Evolution
Old 08-24-2009, 05:00 AM   #1
the 75 Fords weren't metric yet, so it's either a 302 or 351 standard valve in head pushrod engine.
Pull the carb and manifold, then unbolt the exhaust manifolds then the valve covers and rockers, then you can unbolt the head and remove it.. there might be some accessories to remove first..
bernardas is offline   Reply With Quote
Old 08-24-2009, 05:17 AM   #2
spend 20 bucks on a repair manual there are bolts etc that are unique to the place they come from. The 20 bucks is well worth it and it will take you step by step. Look on eBay maybe cheaper
tiberio is offline   Reply With Quote
Old 08-24-2009, 05:46 AM   #3
Do you mean a 1995 4.6? If you do, I may be able to help you with that info. I have access online to alot of Ford repair procedures.
luther is offline   Reply With Quote
Old 08-24-2009, 06:13 AM   #4
there's more to it than i can describe on here,you need a repair manual on that one,that's a big job on that engine,and requires a lot of time and tools,theirs not really enough room here to give good details on it,get a manual is the best advice i can give you on this one,and in 75 they didn't have a 4.6 engine,good luck.
charly is offline   Reply With Quote
Old 08-24-2009, 06:41 AM   #5
that would be a long reply man..go to your nearest auto parts store and get a repair book on it,it gives you detailed pics,directions,specs..everything you need to get the job done...good luck
botulf87 is offline   Reply With Quote
Old 08-24-2009, 07:39 AM   #6
Turn the computer off and pick up your tools.
mathieu is offline   Reply With Quote
Old 08-24-2009, 08:10 AM   #7
You probably would get more accurate answers if we knew where the error lies. Is it a 1975 (in which case it cannot be a 4.6) or is it a 4.6 (in which case it cannot be a 1975)?
tripp is offline   Reply With Quote
11:19 AM
