Whats the biggest engine i can put in a 1973 ford mustang? - Mustang Evolution
Old 08-24-2009, 09:15 AM   #1
i am currently debating on what engine size i should put in my 73 mustang and want to know how BIG i can go
yitzchak8 is offline   Reply With Quote
Old 08-24-2009, 09:38 AM   #2
A 385 series big block (429/460) will fit. As far as displacement, your wallet is the only limiting factor. A good production 460 block with sufficient cylinder wall thickness can be built to 557 cubic inches without even having to do any clearancing. Aftermarket blocks with a standard 10.3" deck height can be built to well over 600 cubic inches.
felan is offline   Reply With Quote
Old 08-24-2009, 09:55 AM   #3
a 460 will go in there.. the 69 model was the first satng to be de
signed to receive a bb without alot of trouble.. the 73 is better yet..good luck.. remember your suspension and dirvetrain will need help as well.
nyle is offline   Reply With Quote
Old 08-24-2009, 10:51 AM   #4
460
keandre is offline   Reply With Quote
Old 08-24-2009, 11:28 AM   #5
You can go as big as you want, depending on your budget.
PAW has some awesome kit motors for this era vehicle.
You could really have anything because there are so many combinations of oversized pistons and cranks to stuff in any block. But I would look at paw , jegs , summit , etc.etc.
bellden is offline   Reply With Quote
Old 08-24-2009, 11:44 AM   #6
I`d also say the 460.
beverley86 is offline   Reply With Quote
Old 08-24-2009, 12:30 PM   #7
they could be ordered with the 429 in 71, which is the same basic block as the 460, so you can go with the biggest Ford there is just use 71 engine mounts...
tobias is offline   Reply With Quote
Old 08-24-2009, 01:06 PM   #8
depending or your pockets and without cutting the frame of the car, you show go with a ford GT 40 engine swap, yummy 550 (bhp) i know a guy with that and omg 0-100 in like 7 sec
primo is offline   Reply With Quote
02:16 PM
