What should my timing be set at on my 1975 ford mustang? - Mustang Evolution
Old 08-24-2009, 11:30 PM   #1
here's the best way to time any car from 1984 on back and a few newer one to.
do total time, not initial, older motors and if the cam or anything else has been changed initial isn't going to get it right for you,
so you want to do total time
and you want
38degrees of total timing @ 3000rpm for a stock motor
36degrees of total timing @ 3000rpm for a motor with a cam
arvad is offline   Reply With Quote
Old 08-25-2009, 12:18 AM   #2
4 cyl auto - 20 degrees
4 cyl stick - 6 degrees
6 cyl auto - 12 degrees
6 cyl stick - 10 degrees
8 cyl auto - 6 degrees
8 cyl stick - 12 degrees
This is for stock engines, you may need to back it off a degree or 2 for today's low octane gas.
beverley86 is offline   Reply With Quote
Old 08-25-2009, 01:17 AM   #3
i like to set my initial timing between 10 and 14 degrees. this gives good performance and decent fuel economy over stock.
bagwunagijik is offline   Reply With Quote
Old 08-25-2009, 01:50 AM   #4
Would you be so kind as to tell us the engine size?
iseabail is offline   Reply With Quote
Old 08-25-2009, 02:42 AM   #5
4, 6, or 8 set them all to 10 degrees, don't forget to disconnect the vacuum advance when hooking up the timing light. if you get any pinging, set it back to 6 or 7 degreesbb
westbroc12 is offline   Reply With Quote
12:07 PM
