Whats the largest motor i can fit in a 1974 ford mustang? - Mustang Evolution
Old 08-25-2009, 02:15 PM   #1
i know the 74 wa a small body and that factory mada a 302 4.9 L V8 the biggest engine... is it possible to fit a 5.0 L from a 80s mustang in it or may be some thing a lil bigger
riordain is offline   Reply With Quote
Old 08-25-2009, 02:48 PM   #2
A 5.0L is a 302. The 4.9L is a 300 6cyl.
Sure, you can drop in any ol' 302/5.0L, the block size is the same. If you want something a little bigger then stroke the 302 to a 347; you can't get anything taller without putting a bulge in the hood.
botulf87 is offline   Reply With Quote
Old 08-25-2009, 03:07 PM   #3
A small block was optional (302 c.i.) stock but these put out less than 175 horsepower! I have seen big blocks swapped in for drag raging (460 c.i.). A late model 5.0 will bolt in and would be a great ride!
ethan is offline   Reply With Quote
Old 08-25-2009, 03:13 PM   #4
the v8 wasn'r offered until 75, so you will have to make the same mods the factory did, like move the radiator support forward...
dagoberto is offline   Reply With Quote
04:48 PM
