1967 Mustang rear end gears.? - Mustang Evolution
Old 08-26-2009, 12:30 AM   #1
I am trying to figure out what gears are in the rear end. Does anyone know what these came stock with? It was originally a 289 with a 2 barrell. It is now a 351W witha T-5 and I am wondering how to tell what is in there already so I do not replace it with the same gears. This is my daily driver but I want to make it a little beefier. I was thinkg 373 for the gears.
odam is offline   Reply With Quote
Old 08-26-2009, 01:10 AM   #2
just answered this same question. go 4.10 or 4.30
iddig17 is offline   Reply With Quote
Old 08-26-2009, 01:47 AM   #3
Check you data plate for the answer on what gears you have. As for what to go with. I just swapped 3rd members out of my 66 Fastback form 2.80 open diff to a 3.25 Trak-Loc and what a world of difference. Gets off the line quicker and still stays low in the rpm range like the 2.80s did. Its the perfect daily driver ratio.
delmon is offline   Reply With Quote
Old 08-26-2009, 02:00 AM   #4
it should have 3.00, check the dataplate on the door..top line, next to last number should be a 1 for the 3.00, or 6 for a 2.80, letters A or F would be for Equa-Lock..
these combinations with a T5 would give it a real tall gearing, like
with the 3.00 at 2000rpm and a .75 od T5 and 25 inch tire gives 66 mph
edoardo is offline   Reply With Quote
Old 08-26-2009, 02:38 AM   #5
Yeah, most likely 2.80 or 3.00 if it's stock.
btw, thinking 3.73 maybe a little too much for a daily. First gear will be wasted for the streets. A 3.55 maybe better.
esra is offline   Reply With Quote
Old 08-26-2009, 03:06 AM   #6
There should be a metal tag on the third member telling you the gear ratio.
trenten is offline   Reply With Quote
Old 08-26-2009, 03:51 AM   #7
The most common gears for those cars where 2.80 and3.00.
daren is offline   Reply With Quote
1967 mustang
12:30 PM
