Can i use 1965 mustang leaf springs on a 1984 truck? - Mustang Evolution
Old 08-26-2009, 01:45 AM   #1
i have a 1984 ford f150 2wd i was wondering if i could use 1965 rear leaf springs on the front there's 3 inches between the mustang leaf springs and the conversion kit for my truck is that a big deal??
bald is offline   Reply With Quote
Old 08-26-2009, 02:04 AM   #2
Car springs are not made to carry the load required from a truck. You can buy helper leafs for your truck. Each one will add 1000 lbs to your carrying capacity.
Coincidently, I've owned both a '65 mustang (coupe w/289,200 hp, 3spd), and an '84 F-150 ( 300 six, 2wd, 4spd). I never messed with the suspension on the 'stang, but I did add 1 leaf to the rear axle of the truck. I paid a spring company, Jenson & Mitchell in Paterson, NJ $200 to make the conversion.
Good Luck
gabrio is offline   Reply With Quote
Old 08-26-2009, 02:23 AM   #3
no, the spring is not strong enough, and to do so you would have to move the front eye forward 1.5 inches and the rear eye back 1.5 inches to center the spring
ashbbie is offline   Reply With Quote
Old 08-26-2009, 03:01 AM   #4
The Mustang leaf springs will not be stiff enough for a truck. I would just go to a junkyard and get some leaf springs off another truck. Leaf springs are cheap. You can probably get a pair for about $30.
howie is offline   Reply With Quote
Old 08-26-2009, 03:20 AM   #5
No.. the weight of the truck will flatten out the springs... springs are designed to work within a particular load rating, so springs from a truck and a car may look the same, but won't preform the same....
kippar is offline   Reply With Quote
Old 08-26-2009, 03:47 AM   #6
conversion kit. explain
deshi is offline   Reply With Quote
1965 mustang
04:07 PM
