Will a 1967 mustang long block v8 fit in a 1966 mustang? - Mustang Evolution
Old 08-26-2009, 06:30 AM   #1
only if it is a small block v8 (289) or 6 cylinder..
huntington is offline   Reply With Quote
Old 08-26-2009, 06:31 AM   #2
Technically it depends on what motor you have. If it's a Big Block 390, 428, or 427 then the other car must have the big block front end. A big block front end will have more room via shock tower removal. If it's a small block 289, 302, 351, then it will fit in either one.
wetherly is offline   Reply With Quote
Old 08-26-2009, 06:59 AM   #3
They didn't make a 1966 Mustang with a 390ci engine. They did put that engine in 1967 Mustand and Cougar. It will fit, but need a good 1967 donor car for all the parts!
albion is offline   Reply With Quote
Old 08-26-2009, 07:00 AM   #4
Yes It should as long as they are 289 or 302.
tedmund is offline   Reply With Quote
Old 08-26-2009, 07:13 AM   #5
Yes, should bolt right in depending on the motor
innis is offline   Reply With Quote
Old 08-26-2009, 08:04 AM   #6
no , you have to take the other engine out first.(_?_)
1966 mustang, 1967 mustang
06:53 PM
