Adjusting 1.6 Rolling tip Rocker Arms? - Mustang Evolution
Old 08-26-2009, 02:45 PM   #1
I have a 1965 Ford Mustang with a rebuilt engine with about 5,000 miles. On the right side of the engine the Rocker Arms are ticking pretty loud. I need some help how to adjust the rocker arms. The Rocker Arms are 1.6 rolling tip rocker Arms....thanks
burkett is offline   Reply With Quote
Old 08-26-2009, 02:50 PM   #2
what sort of cam?
solid lifters need some clearance, but hydralics run with no lash
talk to your engine builder
milward is offline   Reply With Quote
Old 08-26-2009, 03:35 PM   #3
If these are bolt down (ONLY a hex head showing) rockers, they are hydraulic, torque them to 20-25ft/lbs on the bottom of the lobe.
I really can't see installing a solid cam with only roller tip rocker arms. Normally it's done with full roller rockers.
Do some research, but I don't think solid lifters squirt oil out the push rod like a hydraulic lifter does, hence the term solid lifter. I would then turn to Comp Cams or Crane Cams for instructions of how to set your rocker arms, hydraulic or solid.
wendell is offline   Reply With Quote
04:18 AM
