What's the best way to check for a vaccuum leak on my Ford 302? - Mustang Evolution
Old 03-12-2010, 10:00 PM   #1
I have a 1977 Ford Mustang with a 302 in it with an automatic transmission, and I think I have a vaccuum leak. Does anyone know the best way to check this?
colbert31 is offline   Reply With Quote
Old 03-12-2010, 10:12 PM   #2
Ryn
The best way is with a smoke machine. If you don't have access to one, either do a very close visual inspection of ALL vacuum lines, use propane around the intake manifold, or vacuum gauge on all lines. Good luck.
Ryn is offline   Reply With Quote
Old 03-12-2010, 10:40 PM   #3
Tye
here a trick you can do, take dish soap, with water, spary it on the vac hose ,the one that got the bubblel be , the leak
Tye is offline   Reply With Quote
Old 03-12-2010, 11:25 PM   #4
well a vacume gauge is good start. then start engine . a squirt bottle set on stream,squirt water around vacume connections.the rpm will smooth up when you squirt the problem spots,u can do it!
Aulay is offline   Reply With Quote
Old 03-12-2010, 11:47 PM   #5
wd 40
telfor is offline   Reply With Quote
Old 03-13-2010, 12:30 AM   #6
propane with a rubber hose
micheal is offline   Reply With Quote
Old 03-13-2010, 12:34 AM   #7
Soap Bubbles, Vacuum, Bubbles? Its sucks not blows so that wont work. Start engine, spray some WD-40 around suspected area(s), if engine idle changes then you have found your leak...
pueblo70 is offline   Reply With Quote
Old 03-13-2010, 12:40 AM   #8
You can use brake cleaner or a can of quick start. Get 2-3 cans and spray all lines with vehicle running. Listen to the idle, when it drops at a certain area you're spaying at, you found to leak. The other way is by sound sometimes, vac leaks are usually noisy.
varney is offline   Reply With Quote
06:34 AM
