How to remove the two front seats and the back sit off of a 1967 289 mustang coupe ? - Mustang Evolution
Old 03-16-2010, 01:30 PM   #1
I want to replace the seats but the frame on the front of the car that attaches the two front seats to the vehicle doesn't seem to have a bolt or nut or anything. Maybe i am missing something. Can someone please help me.
adir is offline   Reply With Quote
Old 03-16-2010, 02:11 PM   #2
the rear cushion pops up and then You can see 2 bolts that hold the rear back down, remove them and then lift it up..
gilmar is offline   Reply With Quote
Old 03-16-2010, 02:19 PM   #3
Under the front floor pan(on each side) you'll find four holes with rubber plugs. Remove those plugs and then use a socket and extension to remove the nuts which hold the seats. Once the nuts are removed the seats lift right out.
Wren is offline   Reply With Quote
Old 03-16-2010, 02:56 PM   #4
The nuts that secure the front seats to the floor are located under car, the back seat is held in by spring clips and you should be able to just pry it up
finley is offline   Reply With Quote
02:10 PM
