FORD MUSTANG BRAINIACS what does r-code and/or c-code mean? - Mustang Evolution
Old 03-16-2010, 03:30 PM   #1
i have been looking into buying a mustang between the years of 1964 1/2-1968 and i came across a beautiful '68 fastback that had 'r-code' in the description. that peaked my curiosity so i have been googling to see what it is and the only thing i have found is that a c-code exists and i believe the r-code was either only made in '68, or NOT made AFTER '68. thanks in advance!
ps if anyone wants to either buy me one or give me one i won't complain!!!
kele74 is offline   Reply With Quote
Old 03-16-2010, 03:51 PM   #2
The codes pertain to the engine with which it's equipped. The "C" code is a 289 C. In. V8 with a 2 barrel carb while the "R" code is a 427 Cu. In. V8 with (2) 4 Barrel carbs. The R code was basically built to eat Camaros on the drag strip and will bring a pretty penny if it's truly an original "Factory" R Code. IF you decide to buy an expensive Mustang try to locate a local Mustang club and get someone knowledgeable to look at it with you. There are a lot of fakes out there as a lot of the goodies could be purchased across the counter from the dealers. That doesn't make them worthless, if they were done right but it doesn't make them as valuable as a car that is equipped that way from the factory. As to buying you one. HA! My grandson completed a restoration, last year, of the '65 his father father bought shortly after he graduated from high school. We put over $30,000 into that restoration and the only work we didn't do ourselves was the paint.
bishamon90 is offline   Reply With Quote
Old 03-16-2010, 04:12 PM   #3
Scott has the right codes mostly, 170 is U, it and D and F are 64 1/2 only
cruz is offline   Reply With Quote
Old 03-16-2010, 04:49 PM   #4
Here's the different codes that Ford used on their Mustangs:
Model......65..66..67..68..69..70
170.........V
200.........T.....T....T....T...T....T
250...............................L..L
260 (V8)...F
289 2V.....C...C....C....C
289 4V+...D
289 4V.....A...A....A
289 HiPer..K..K....K
302 2V............................F...F
302 4V......................J
302 4V Boss...................G...G
351 2V*...........................H...H
351 4V**.........................M...M
390 2V......................Y
390 4V......................S....S....S
427 4V......................W
428 4V......................P
428 4V CJ........................O...O
428 4V SCJ......................R...R
429 4V Boss.....................Z...Z
The last year for the C code was 1968.
The first year for the R code was 1969.
JosT is offline   Reply With Quote
Old 03-16-2010, 05:12 PM   #5
C code = 289 ci 1965 & up
R code =427 hi -perf 1967 & up
lachlan is offline   Reply With Quote
05:02 AM
