I have a 66 mustang! Bad news is that I have lost the only set of keys.? - Mustang Evolution
Old 03-20-2010, 05:00 PM   #1
As I said I have lost the only set of keys, and need to know how to replace the ignition tumbler, and the trunk tumbler. Is it possable without a locksmith? any help will be appreciated.
gail is offline   Reply With Quote
Old 03-20-2010, 05:25 PM   #2
Give your Ford dealer the VIN (vehicle identificaton number)(found on the drivers side of the winshield, only visible fom outside) and ask tem to make u a couple copies of the keys.
esra is offline   Reply With Quote
Old 03-20-2010, 05:27 PM   #3
I would recommend getting a new lock set from one of the classic Mustang venders.
At a minimum, I would get the ignition lock. The door and trunk locks are easily removed and you could take these to a locksmith and have new keys cut or the door locks could be recoded to your new ignition keys.
www.cjponyparts.com
www.mustangsunlimited.com
www.mustangdepot.com
www.cal-mustang.com
www.dallasmustang.com
www.mustangdepot.com/OnLineCatalog/parů
etc....etc......etc
wylingford is offline   Reply With Quote
Old 03-20-2010, 06:20 PM   #4
The entire ignition switch comes out of the dash as does the door locks and trunk and glove box locks. Either available as a whole set from Classic Ford parts sellers or just have a Locksmith over to make you up a couple sets of keys and an extra one to hide.
aswynn95 is offline   Reply With Quote
Old 03-20-2010, 06:25 PM   #5
I would suggest taking the locks out and taking them to a locksmith. This is a good deal less expensive than paying for mobile service, and is likely less expensive than replacing the locks. Plus the fact that aftermarket locks may very well be lower quality and may corrode quickly.
Old 03-20-2010, 06:50 PM   #6
Any locksmith can make a matching key in only a few minutes. My friend lost the only keys to his 66 Ford and the locksmith made a set of keys from the passenger door lock (on the car) in less than 2 minutes.
annawan is offline   Reply With Quote
» Members Mustangs
Baby
GWraith
Falcon
Diemick
Add your Mustang
12:32 PM
