Will an older tranmission work on a newer car? - Mustang Evolution
Old 03-20-2010, 09:45 PM   #1
I'm am building a 1970 ford mustang and i was wondering if i can buy a 1964 transmission and if it would fit?
imported_Andreas is offline   Reply With Quote
Old 03-20-2010, 09:59 PM   #2
For the sake of sanity, you are talking about either a C4 or C6. Anything else, you're on your own... it's a road less traveled.
You should read this article regarding the C4 and it's history:
http://www.mustangandfords.com/techa...ion/index.html
Then review if you want the ol' '64 in your ride. Do it in a pinch and if it's free but you'll eventually want to upgrade to a newer one - maybe even an AOD.
custennin is offline   Reply With Quote
Old 03-20-2010, 10:25 PM   #3
It really depends on what transmission and engine combination you are talking about. I have a 1964 Galaxie 500 XL 2dr with a 1970 390 hooked up to a stock 1964 Cruisomatic trans which is the large 3 speed with green dot drive. If your engine is a 302 then I suggest a C4 trans. The big block cars should all have C6 autos or 4 speed in those years. It is much easier to swap an engine around in those years than a trans because of the difference in years. The engine will bolt up but it might have problems clearing the firewall along with the correct tranny mounts and cross member. You would need the existing bell housing from the 70 also. What engine and trans?
riki is offline   Reply With Quote
Old 03-20-2010, 11:16 PM   #4
didnt they change shape about 3 times?
and improve power
even if it fitted, it wouldnt handle the power
nahcomence is offline   Reply With Quote
02:02 PM
