Classic Mustang overheating? - Mustang Evolution
Old 03-30-2010, 05:15 PM   #1
I have a 1968 mustang with a 289 engine. It normally runs pretty well, but when I took it out of storage this year it started overheating and then coolant started flowing out on the floor infront of the passenger seat. What happened and how do I fix it?
Berwick is offline   Reply With Quote
Old 03-30-2010, 06:03 PM   #2
it probably overheated because the thermostat stuck,causing the other problem. Put in a new thermostat and antifreeze..
meyer41 is offline   Reply With Quote
Old 03-30-2010, 06:07 PM   #3
Disconnect your hoses and put a short loop on your engine to bypass the heater core. If your car runs good and you don't overheat/loose fluid then you need to replace your heater core before winter. Otherwise you have other problems and you need to look for the new leak or thermostat.
Renfrid is offline   Reply With Quote
Old 03-30-2010, 06:47 PM   #4
Either the heater core failed, or the hoses to the heater core failed. As well, it probably overheated due to the loss of coolant.
Heater cores are not hard to replace, but if you are not mechanically inclined it is time to take it to a mechanic.
imported_travis is offline   Reply With Quote
Old 03-30-2010, 07:05 PM   #5
I agree. It is probably the heater core. If the hoses are attached outside the firewall then it probably won't be a hose. If the are attached inside the car they could be leaking at the end, but my money is on the core.
conroy is offline   Reply With Quote
Old 03-30-2010, 07:35 PM   #6
Remove the core, flush it, check the thermostat.. it could be stuck like they said, replace the hoses, and top it off.. then beat the snot out of it if does it again!
bizahalani is offline   Reply With Quote
Old 03-30-2010, 08:00 PM   #7
the heater core my 68 did the same thing replace the heater hose going to the core also and clamps youre it will save you trouble later
colbert31 is offline   Reply With Quote
Old 03-30-2010, 08:19 PM   #8
Either heater hose busted or heater core
ferrant is offline   Reply With Quote
Old 03-30-2010, 09:03 PM   #9
Pedro is right on the $. I had a same problem on my 67 mustang years ago.
02:38 PM
