What Ford 4 speed automatic transmission will bolt up to a1976 302 engine? - Mustang Evolution
Old 12-12-2011, 12:15 PM   #1
I bought a 1961 Ford unibody that has a 1976 Mustang 302 engine and 3 speed automatic transmission. I would like to replace it with a 4 speed automatic. Any help would be appreciated.
annawan is offline   Reply With Quote
Old 12-12-2011, 12:53 PM   #2
The AOD is your best bet, unless you want to start messing around with electronic shift versions (there are controllers available for the AOD-E/4R70W, not sure about the A4LD). Some of these may have had lock-up torque converters, but you can just leave that unplugged if that's the case (they run off the ECM, which a '76 302 ain't got). You'll need one that has the correct bellhousing pattern, which is known as the "Late Windsor". More info in these 2 links. Cross-reference the models at the top of the 1st link with the engines in the 2nd link (right-hand column only), and if it has a 4 speed auto, it should be an AOD.
http://en.wikipedia.org/wiki/Ford_AOD_transmission
http://en.wikipedia.org/wiki/List_of...sor_V8_pattern
http://en.wikipedia.org/wiki/Ford_A4...nsmission#A4LD
More info on the AOD here, and the AOD-E/4R70W on page 3;
http://www.carcraft.com/techarticles..._ford_aod.html
Hurlbart is offline   Reply With Quote
Old 12-12-2011, 01:16 PM   #3
Thanks for the help.
brant is offline   Reply With Quote
Old 12-12-2011, 01:59 PM   #4
Jem
first you have to find out if both have lock-up converters. another thing you should use the torque converter that came with the 4 speed.
Jem is offline   Reply With Quote
Old 12-12-2011, 02:11 PM   #5
AOD is what you want.
fahyim is offline   Reply With Quote
Old 12-12-2011, 02:57 PM   #6
your first answer
Orbart is offline   Reply With Quote
08:26 PM
