1964 mustang question? - Mustang Evolution
Old 12-13-2011, 06:30 AM   #1
if i convert it to a v8 will it go to at least 200............i ask a technician he said it would...........im also thinking about putting a turbo charger on it....please help?
Kynlas is offline   Reply With Quote
Old 12-13-2011, 07:01 AM   #2
200 what, HP? yes, KPH? maybe, MPH? NO..
and even though it was made in 64, it's still a 1965..
added: It's a brick! so it wouldn't go 200 mph if you had 1,000 HP.. it will lift off and fly first!
plus with with suspension it has you won't be able to keep it on the road at 120 mph..
the stock six, does 90 to 95 at 4100 rpm's with 3.20 rear axle...depending on tire size..
the stock V8 does 115 to 125 depending on 2v or 4v carb with a 3.00 axle..
imported_Wallace is offline   Reply With Quote
Old 12-13-2011, 07:12 AM   #3
I've owned several of 65-66 'stangs & I would not want drive one over 100-110 mph! The six cyl. turns about the same RPMs as a 8 cyl, so the top speed will not be that different unless you are planing to do something with your gear ratios.
Maureo is offline   Reply With Quote
1964 mustang
04:01 AM
