347 stroker missing under acceleration? - Mustang Evolution
Old 12-16-2011, 05:15 AM   #1
i have a 1978 mustang with a 347 stroker, it has a holley 600 cfm intake a cam and a weiand intake. i have put new plugs wires and cap on the car but it still seems to miss under acceleration. it has a new ICM. all it may need is a good tune but i have tried that and i cant gat anywhere, can anyone help me??
imported_Matt is offline   Reply With Quote
Old 12-16-2011, 05:20 AM   #2
i had a Corvette that did the same thing and it was a bad plug. i would go that route first. its probably a spark issue but that depends on how old the motor and its components are. could be a valve leaking, bad lifter, gummed carb, etc.`
felippe is offline   Reply With Quote
Old 12-16-2011, 05:47 AM   #3
only time a car misses under acceleration is because timing is out. or the carb neeeds a complete rebuild. if you have a new holley 600 then yes its timing is out wont be by much but few mins with a timing light and will be sorted.
raedford is offline   Reply With Quote
Old 12-16-2011, 06:36 AM   #4
I'm with Jane...bad plug........Take a spray bottle with water and spray the headers. This will help you find the "cold" hole. Or, open the hood after dark and check for errant sparks on a running engine
bald is offline   Reply With Quote
Old 12-16-2011, 06:41 AM   #5
Check the timing then look for a vacuum leak.
Kynlas is offline   Reply With Quote
Old 12-16-2011, 07:29 AM   #6
Coil or plugs.....
Giollanaebhin is offline   Reply With Quote
11:19 AM
