I have a automatic 1973 mustang and it wont go past 1st gear? - Mustang Evolution
Old 12-16-2011, 01:30 PM   #1
gil
i noticed it yesterday while i was driving and i was picking it up to 40mph and it wudnt switch gears and the rpms were about 3500 rpm
can anybody give me an idea of what could be the problem?
i also noticed that the carburator was leaking gasoline from where its connected to the manifold
gil is offline   Reply With Quote
Old 12-16-2011, 02:08 PM   #2
It could be a linkage problem, or low oil level, or blown out modulator, or internal problem.. take it to a transmission shop for a estimate..
AND FIX THAT GAS LEAK!
currito is offline   Reply With Quote
Old 12-16-2011, 02:17 PM   #3
fuel leak is important to fix wil not be connected to gearbox issue,
check fluid level in gearbox . if ok? check all vacum and linkages to gearbox/ engine.
failing that intrenal valve for brake band. actuator effecting gear change will have failed. you may be able to get an easy fix but often an exchange tranny is best. use an auto box specailst or trusted garage only.
Lynd is offline   Reply With Quote
Old 12-16-2011, 02:39 PM   #4
you might check your tranny fluid and make sure there is no red fluid underneath where u park ur car and if u didn't know already an automatic transmission runs off of pressure so if u dont have enough pressure it may not work at all, to check ur tranny fluid park the car in neutral and pull the tranny fluid fill dipstick and check the fluid.
carne is offline   Reply With Quote
Old 12-16-2011, 02:44 PM   #5
Make sure there's vacuum at the vacuum modulator on the transmission.
Bearach is offline   Reply With Quote
Old 12-16-2011, 03:04 PM   #6
Vacuum modulator or governor.....
Baldwin is offline   Reply With Quote
Old 12-16-2011, 03:50 PM   #7
rebuilt the motor
its not that hard
i do it all the time to my japanese tuner
so dont complain
1973 mustang
02:52 AM
