T5 tranmission out of a 90's mustang wanting to put it in a 1978 mustang? - Mustang Evolution
Old 12-16-2011, 11:30 PM   #1
how can i make it work does the bell housing unbolt and what type of bell housing do i need if it unbolts
Redd is offline   Reply With Quote
Old 12-17-2011, 12:27 AM   #2
Use the 5.0L bellhousing, BUT.....if your '78 Mustang is a V-8 you'll need a 302 flywheel with a 28 oz. imbalance. A post '80 5.0L uses a 50 oz imbablance flywheel and will break your crankshaft.
imported_Garth is offline   Reply With Quote
Old 12-17-2011, 12:52 AM   #3
Ryn
Usually, a pre-1980 flywheel for a 302 (or most SBF's) will be the 28 oz. Think of the 302 as having died a "metric death" in 1979, then being reincarnated as the "5.0L" in 1980. I'd buy the flywheel new.. You might get stuck with a 50 oz. if you go the E-Bay route.
Ryn is offline   Reply With Quote
Old 12-17-2011, 01:22 AM   #4
You'll need a new bell, trans mount, shifter, clutch linkage and driveline...."put a wide ratio RUG in a II, with a little grinding on the doughnut rar the stock manifolds work.
The oversize bell may require spacing the radius arm bracket cross member back a little (in one car it didn't , in the other car it did).
RUG shifter needs spaced back 1 1/2 inches more or less". .....
Eairrdsidh is offline   Reply With Quote
1978 mustang
08:07 PM
