Can i put a torino frame on a 1972 mustang fastback? - Mustang Evolution
Old 12-17-2011, 01:15 AM   #1
Both cars are unibody and completely differrent.Will not work.
skah is offline   Reply With Quote
Old 12-17-2011, 02:15 AM   #2
Forget it, not gonna happen !! There IS no easy way - If you want the repair to last......
The Mustang is (and always has been) a unibody car. That's why Ford could build them so cheaply before unibody became an industry standard.
When you have frame damage to a vehicle, you have to bend, straighten and weld until the repair is finished. Spot welding won't last very long. After you hit too many potholes, the spotwelds will crack and break, then you have to start all over again.
Carney is offline   Reply With Quote
Old 12-17-2011, 02:35 AM   #3
You mean under a fast back body? You would probably have to modify it or the body as the Torino was longer. The Mustang had its own frame it did not share it with another model.
I added a link for frame replacement on Mustangs see below
wolf is offline   Reply With Quote
Old 12-17-2011, 03:11 AM   #4
NO WAY! Neither car came with a frame! That said, the front clips might be interchangeable since they were built on the same platform..but it would be a lot of work, including some welding..
They were both designed for Ford's big block 429 engine..
ann15 is offline   Reply With Quote
Old 12-17-2011, 03:24 AM   #5
any thing can be done with the skills and the tools, It would be a ton of work ,mustangs are shorter and narrower ,not sure what you are trying to gain,
Rayman is offline   Reply With Quote
Old 12-17-2011, 04:04 AM   #6
Its easier the other way around, put mustang stuff on the torino
Rhys is offline   Reply With Quote
Old 12-17-2011, 04:24 AM   #7
if you want to put it on
imported_Matt is offline   Reply With Quote
1972 mustang
10:43 AM
