Pictures of installing electric fuel pump on a 1972 mustang? - Mustang Evolution
Old 12-17-2011, 01:30 AM   #1
need to know how to connect it right
jakome is offline   Reply With Quote
Old 12-17-2011, 02:00 AM   #2
Just make sure you get a low pressure, 6 lbs, pump for carbs and not a fuel injection pump.. the easiest place is on the fenderwell next to the old pump..you might want to get a blocking plate and remove the mechanical pump.... the power needs to come from the ignition switch so it goes on and off with the ignition..
felippe is offline   Reply With Quote
Old 12-17-2011, 02:36 AM   #3
You don't need a picture because you can mount it anyway you want. The is a definite in and out, but there is usually only one power wire, since the chassis mount is the ground.
arlee is offline   Reply With Quote
Old 12-17-2011, 02:51 AM   #4
you should get a shop manual for it (the mustang)
gallagher46 is offline   Reply With Quote
1972 mustang
04:42 PM
