Can Somebody Tell what's wrong with my 1965 Mustang.? - Mustang Evolution
Old 12-17-2011, 07:15 PM   #1
The car sounds like wants to turn off while it's on neutral or when Iím on a complete stop Ö It sounds good while driving it but then again when Iím on a stop light Ö itís sound weak like if itís gonna turn off on me. What possibly can it be? Today is the first time it happened
beverleigh is offline   Reply With Quote
Old 12-17-2011, 07:54 PM   #2
It could be just a idle adjustment on the carb needs to be sped up or the ignition points are getting worn, retarding the timing which slows down the idle...a new set of points properly gaped would probably fix it..
bald is offline   Reply With Quote
Old 12-17-2011, 08:06 PM   #3
Your engine has carburetor, one of the components of a carburetor are idle jets. They are what controls the amount of fuel that the engine gets at idle but if they're partially or fully clogged the results are similar to the symptoms you describe. How long since the carb has been cleaned? Once you accelerate, the main jets are controlling the fuel so there's no issue at speed, only at idle. There could be other reasons also but I'd start with the idle jets if the carb hasn't been cleaned in a long time.
Additionally, check the fuel pump to be sure you're getting fuel pressure, yours is mechanical, mounted on the engine block, not electrical. Check also the fuel filter if equipped.
imported_Roderick is offline   Reply With Quote
Old 12-17-2011, 08:53 PM   #4
Could be some carb adjustment like the idle, idle mixture, choke, etc..
but I would look if the distributor vacuum advance hose got disconnected.
odam is offline   Reply With Quote
Old 12-17-2011, 09:21 PM   #5
sounds like the sparkplugs are fauling out. or could be it the timing
imported_ricardo is offline   Reply With Quote
1965 mustang
04:46 AM
