Car stalling while driving? - Mustang Evolution
Old 12-18-2011, 02:00 AM   #1
i have a 1978 mustang and out of no where, my car starts up perfectly fine but after around 3 minutes of driving my car will start to stall and just die out.... but it will start right back up but will die around 10 seconds after if i start driving, but i can let it idle, now after around 10 minutes of my car being on my car will start up and not be able to drive at all without dying out.
nyle is offline   Reply With Quote
Old 12-18-2011, 02:32 AM   #2
First thing you need to do is replace the fuel filter. If that doesn't fix it buy a can of carb and choke clean an spray the hell out of the carburetor. If those 2 cheap fixes don't work check to see if the choke is working properly.
llevelys is offline   Reply With Quote
Old 12-18-2011, 02:54 AM   #3
check you air and fuel filter you may also need to clean your carburetor.
Eairrdsidh is offline   Reply With Quote
Old 12-18-2011, 03:07 AM   #4
sounds like a fuel problem, check filter and replace fuel pump
beshiltheeni is offline   Reply With Quote
06:17 PM
