1973 Mustang oil pressure dropping to zero while in gear.? - Mustang Evolution
Old 12-18-2011, 04:15 AM   #1
I was going to take it out for a drive today and as soon as I put it in gear, my oil pressure drops immediately to zero. I just changed the oil and with the dipstick it says that it is full. Any idea on what could be the problem? When I put it back into park it does to normal again.
dagoberto is offline   Reply With Quote
Old 12-18-2011, 04:57 AM   #2
replace the oil pressure switch and see what happens before you worry about anything else.
imported_karsten is offline   Reply With Quote
Old 12-18-2011, 05:29 AM   #3
check iol presser switch first . fords rods an main berring hold oil presser. so with high miles on motor wear in berrings . oil light would come on at a idal . on chevys cam berrings hold oil presser . . so if bearings on fords . have on old fords drop oil pan an put new standrad rod an main berrings in an cured up this problim . an what weigh oil did you use 10w40 is good
felan is offline   Reply With Quote
Old 12-18-2011, 06:24 AM   #4
change the oil sending unit first. if it still does it then it could be a weak oil pump or a rod bearing.
boothe is offline   Reply With Quote
1973 mustang
08:40 AM
