1966 mustang timing advance? - Mustang Evolution
Old 12-19-2011, 03:30 AM   #1
if i modded the timng advance would it be bad or good and is it hard to do
dubv12 is offline   Reply With Quote
Old 12-19-2011, 04:00 AM   #2
The more power you can make with less timing, the better. Getting fuel to vaporize will reduce spark advance requirements.
For now, unplug the vacuum advance while you set timing. 10 degrees initial at 800 RPM is a good baseline to start with. Ideal, learn how to read the spark plug and it can tell you all sorts of things... including if the engine is happy with the timing setting or not.
Email: camshaftshaun@gmail.com
Channon is offline   Reply With Quote
Old 12-19-2011, 04:51 AM   #3
a little wouldn't hurt, but I would try just setting the initial at 10 first.. they make special springs to mofify the advance curve..
Added: with todays gas, you can't go much more than 10 without risking detonation..
Jacobo is offline   Reply With Quote
1966 mustang
06:45 AM
