Anybody with car electrics experience have a clue with a 1973 mustangs wiring? - Mustang Evolution
Old 12-19-2011, 08:45 PM   #1
Jem
I have a 1973 mustang and i was checking my windows and i checked the windows motors and they worked properly and i checked the window switches and the work properly to but i don't know what the problem is because it will go down but not up any suggestions will be appreciated
Jem is offline   Reply With Quote
Old 12-19-2011, 09:01 PM   #2
Sounds like a switch or a weak motor. How did you check the switches? Make sure you check them with current flowing through them and not just ohm them out. They will break down when you apply them and the motor wont get enough current flow through the switch to go up. Use a current clamp at the motor leads and see how much your getting on up. Old switches is my guess. You can also use a battery to reverse polarity at the motor leads bypassing all switches to be sure the motor isn't bad in one direction and that's highly unlikely but it does happen. I had a 73 convertible in 79 and I sure do miss that ride!
Waldemar is offline   Reply With Quote
1973 mustang
05:29 PM
