No spark from my 1966 mustang? - Mustang Evolution
Old 12-21-2011, 02:15 AM   #1
change the points, coil, plugs and wires, it cranks but no spark
westbroc12 is offline   Reply With Quote
Old 12-21-2011, 02:27 AM   #2
Are the points gaped to 0.015 inch ? be sure and use new points and condensor...trying to file the points is a waste of time and don't forget the rotor..... make sure you have the proper firing order and in time......
did you check compression? if it's been sitting for a while, add a little light oil or wd40 down the carb to help seal the rings and build compression..
colton is offline   Reply With Quote
Old 12-21-2011, 02:45 AM   #3
when you change the points,coil,wires .....there is no mention of setting to # 1 TDC Go back and do set it at # 1 TDC Then at that THE rotor should point genarally to 1 (rotor)Now have friend slowly turn the crank sahft AS you watch the points travel on the high points and back to the low points at the same time watch the rotorwhen there is a spark some adjustment is well going to be in the Distributor cap bye
Channon is offline   Reply With Quote
Old 12-21-2011, 02:50 AM   #4
Did you replace the "Condenser"? That's an important part of the ignition system too. Read below for hints at problem.
http://www.familycar.com/Classroom/ignition.htm
pueblo70 is offline   Reply With Quote
Old 12-21-2011, 03:33 AM   #5
check the distributor if you had it out it could be 180 degree out.
fahyim is offline   Reply With Quote
1966 mustang
04:15 PM
