Were there 390 engines that came factory with 67 and on mustangs? - Mustang Evolution
Old 12-21-2011, 06:45 AM   #1
My friend doesn't believe me when I tell him this (I know for a fact that there were mustangs ordered with 390's), so I figure if a lot of other people tell him and post proof (links, pic's, etc.) it would be greatly appreciated. Thanks, Sam
btw my friend's name is Nick, and he has a 1967 mustang coupe 289 2v, I have a 1968 mustang fastback 302 4v (his is apparently faster )
Garwyli is offline   Reply With Quote
Old 12-21-2011, 07:21 AM   #2
Yes. They were 390-cubic-inch 6.4L V-8 engines. Check out the link below. Hope this helps. Good Luck.
http://mustangs.about.com/od/modelye...67-profile.htm
Orson is offline   Reply With Quote
Old 12-21-2011, 08:16 AM   #3
sure they had 390s back in the 60s and even the 70s. i had a 70 LTD that had a 390. if you have that 302 tuned up good you could run circles around his 289. a 289 is a good engine but a 302 and 390 is better.
felippe is offline   Reply With Quote
Old 12-21-2011, 08:24 AM   #4
Stock Engines Available in 67
200cid 6cyl 1V 120hp
289cid 2V V-8 200hp
289cid 4V V-8 225hp
289cid 4V V-8 271hp
390cid 4V V-8 320hp
imported_burn is offline   Reply With Quote
Old 12-21-2011, 08:40 AM   #5
The cylinder heads from these 390 GT motors are also the only FE-series head to use 4 bolts on the exhaust ports.... the 390 GT heads were the predecessors to the vaunted 428 Cobra Jet cylinder heads
adair is offline   Reply With Quote
Old 12-21-2011, 08:47 AM   #6
The 1967 Mustang could be ordered with the 390. Engine code S
Evelyn is offline   Reply With Quote
Old 12-21-2011, 08:58 AM   #7
Yes, and Shelby even put the larger 428 FE in his '67 Shelby GT500...
coty is offline   Reply With Quote
Old 12-21-2011, 09:31 AM   #8
never seen one, I know in 68 they had them
ramzi is offline   Reply With Quote
Old 12-21-2011, 09:55 AM   #9
it was a special option to install a Thunderbird 390 into certain 67 mustangs.They're rare though.
http://www.ehow.com/list_7605232_196...g-options.html
cipriano is offline   Reply With Quote
04:37 AM
