What can cause older engine to misfire and have lack acceleration? - Mustang Evolution
Old 12-23-2011, 05:30 PM   #1
i have a 1971 mustang with a 351 cleavlend and it runs good but when accelerating it has little miss fires and when i get going above 20 and give it a bit of gas it seemes slugest. it makes noice but doesnt really throw you back in the seat like it use to. i put a new timing chain and cleaned the carb . it does have what lookes like the stock coil though. so can you help me out ?
llyr is offline   Reply With Quote
Old 12-23-2011, 06:18 PM   #2
Complete tune-up would be in order; i.e., spark plugs, points, condensor, Make sure you set the correct gap in the points and the plugs. Also might as well throw in some spark plug wires. I wouldn't suspect the coil but what the hey..change that too!
bayerd is offline   Reply With Quote
Old 12-23-2011, 07:01 PM   #3
problem fixed it was the timing it was a bit retarded, its a rocket now holy pie!!! 25 mph and able to brake loose and burn rubber
camden is offline   Reply With Quote
Old 12-23-2011, 07:29 PM   #4
Sounds like it needs a full tune up.
Being '71 it's still got a points ign. system. Points wear, burn and crack alot. If you can, swap it to an elec. dizzy.
New plugs, cap, rotor, plug wires, points if staying with them, check and set timing, adjust carb for highest vac readings on a vac gauge., new fuel filter
The carb may be in need of a rebuild as well
Wren is offline   Reply With Quote
Old 12-23-2011, 08:27 PM   #5
I would advanced your timing a little bit, and if that don't help, I would go for a tune up. If it's been awhile since you tuned it up, I would go ahead and put new plugs and plug wires in it.
imported_Corey is offline   Reply With Quote
Old 12-23-2011, 09:06 PM   #6
my charger was doing sort of the same thing. i cleaned my plugs replaced and upgraded my ignition to an MSD unit. i also replaced my wires and my distributer. then i tuned it timed it and it ran great.
Gyles is offline   Reply With Quote
Old 12-23-2011, 09:29 PM   #7
I agree with the timing comment. Could also be a problem with the carb depending on the last time you replaced it.
stanley is offline   Reply With Quote
Old 12-23-2011, 10:04 PM   #8
sounds like you need to advance your cam timming just a hair
berdy is offline   Reply With Quote
02:40 AM
