Installing C4 transmission, help!? - Mustang Evolution
Old 12-24-2011, 03:45 AM   #1
So, swapping out the junky 3 speed set up on my 1967 mustang (3.3L 200 inline 6 motor). Putting in a rebuilt C4 and having some troubles. I have everything hooked up, torque converter to flexplate, no troubles, and tranny is bolted to the engine block. My problem is that, when I was bolting up the torque converter, the flexplate spun around for me to mat all 4 bolts. Once I had the tranny bolted to the engine block, it won't spin freely anymore. And, yes, the gear selector is in Neutral and all 4 tires are off the ground.
So, question is, should it still spin freely enough? If I were to turn the radiator fan, shouldn't it still spin like it did when I was bolting it up? Or shouldn't I be able to spin the drive shaft and get movement?
Side question, but possibly related, I'm not missing anything am I? I have the C4, the proper torque converter and bell housing, the proper flexplate and proper inspection plate. Is there something like a spacer that is supposed to be in there as well? There was nothing when I removed the manual tranny but thought I'd check. Last thing I want to do is spin this thing up and have it tear apart the $400 tranny rebuild.
Any help would be great!!!!!!!
merlow26 is offline   Reply With Quote
Old 12-24-2011, 03:50 AM   #2
Did you remove the pilot bearing from the crankshaft ?
tiberio is offline   Reply With Quote
Old 12-24-2011, 04:42 AM   #3
yitzchak8 is offline   Reply With Quote
Old 12-24-2011, 04:52 AM   #4
Pilot bearing in the crankshaft?? If you did not remove it then you just busted the pump gears.
cheng-gong is offline   Reply With Quote
02:09 PM
