My car wont start - Mustang Evolution
Old 01-18-2013, 09:08 PM   #1
Tyoung68's Avatar
My car wont start
It was tuning over fine wasn't sluggish or anything an it wouldnt catch so i stop turn the key back to start and nothing happened it just clicks once ? What could cause this? Iv bypassed the n.s.s. and iv charged my battery still nothing. Iv even taped on the starter with a hammer still nothing im confused
Old 01-18-2013, 09:46 PM   #2
Aggiesrok's Avatar
Is it an auto?
Old 01-18-2013, 09:55 PM   #3
Tyoung68's Avatar
Yes. A 200 l6 with a c4
Old 01-18-2013, 09:59 PM   #4
Aggiesrok's Avatar
My sons 67 does that sometimes. It is dead but if you push forward a little on the shifter it will start or it will start in neutral. The neutral switch needs to be adjusted or replaced, I haven't had time to check yet. Try putting it in neutral and see if it starts.
Old 01-18-2013, 10:26 PM   #5
Tyoung68's Avatar
I dont have the n.s.s hooked up i bypassed it i got a new wiring harness and found out that it was broken and i havent had the cash to get a new one yet so i know the n.s.s isnt the problem
Old 01-18-2013, 10:40 PM   #6
Aggiesrok's Avatar
Do any other items work, lights, radio, horn, etc?
Old 01-18-2013, 10:53 PM   #7
Tyoung68's Avatar
Yes they all work
Old 01-18-2013, 11:52 PM   #8
Aggiesrok's Avatar
Yes they all work
Are you sure you bypassed the NSS and didn't wire it open? Probably a silly question. What about the starter relay, those go out.
Old 01-19-2013, 10:45 AM   #9
Commercial Member
matcox83's Avatar
Start even more basic. If the battery voltage is good with a voltmeter from pos to neg post, then check voltage drop on each terminal. Check the voltage from each post to the corresponding terminal. If you show voltage it means you have high resistance due to dirty or bad connections. Try cleaning them. You can have enough juice to turn things on but not start the car
Old 01-19-2013, 06:20 PM   #10
Tyoung68's Avatar
The solenoid wasnt ground it starts up fine now
Old 01-19-2013, 08:13 PM   #11
Commercial Member
matcox83's Avatar
We're you able to tell what caused the bad ground? It just screws to the inner fender. Was it rust?
Old 01-19-2013, 08:41 PM   #12
Tyoung68's Avatar
I noticed it was lose i used self drilling screws and i over tightened them and stripped it i guess i just moved it over a little ad drilled new holes
Old 01-20-2013, 05:52 AM   #13
Commercial Member
matcox83's Avatar
That's a lesson learned for everyone. Thanks for telling us.
Old 01-20-2013, 07:21 AM   #14
Tyoung68's Avatar
No problem! Thanks for all the help
05:56 PM
