351w Question? - Mustang Evolution
Old 02-07-2013, 04:40 PM   #1
MG1969Coupe's Avatar
351w Question?
Hello all, I have a 1969 coupe and it currently has a 302 in it and I want to upgrade to a 351w in the future. I have a question. I have been told that pre 1973 351w motors are the best to try and get because the later years are choked down and don't make as much power. I was wondering if this is true? What are the best year motors to try and get or does it not matter?
MG1969Coupe is offline   Reply With Quote
Old 02-09-2013, 01:43 PM   #2
rbohm's Avatar
all 351ws are good motors, the heads are all pretty much the same, though after 1976 or so they do have slightly smaller ports and valves. in the end its no big deal though as you can still make good power from a 351w. and if you dont like the stock heads then grab a set of aftermarket heads and make all the power you want. by the time you spend the money to improve the stock heads, you can buy a set of complete ready to bolt on world products windsor sr heads in cast iron, and for not much more you can get them in aluminum.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
Old 02-09-2013, 02:37 PM   #3
Alright thanks a lot yea I'm planning on getting a 351w and upgrading it. Better than my 302 even though it's making decent power with the bolt ons I have on it already
Old 02-09-2013, 02:50 PM   #4
2300turboford's Avatar
71-79 are the best bc the are a thicker casting
Old 02-09-2013, 02:55 PM   #5
Alright I'll keep that in mind thanks
Old 02-11-2013, 08:44 PM   #6
Bravebowhunter's Avatar
I heard 1969 was the best year for the strength of the block and then you can always get what ever heads cam intake and carb combo you want but make sure they all compliment each other.
Bravebowhunter is offline   Reply With Quote
Old 02-12-2013, 03:25 PM   #7
Hey everybody, what would be the best heads for a 351w? The car is not a track car but I would definitely like it to have some power going down the road.
Old 02-12-2013, 03:38 PM   #8
No 69 has a shorter deck
---------- Post added at 05:38 PM ---------- Previous post was at 05:38 PM ----------
Factory or after market
Old 02-12-2013, 07:19 PM   #9
rbohm's Avatar
actually as i said all 351w blocks are good for building a healthy street motor. there is no "best" year, as they can all handle about the same amount of power before they split, which is north of 600hp for a stock block.
as to the best year for cylinder heads, the best ones for factory heads are the 69/70 heads.
Old 02-12-2013, 09:02 PM   #10
Ok thanks for the info. What aftermarket heads would you recommend?
Old 02-13-2013, 04:24 AM   #11
Afr all the way. Best on the market
Old 02-13-2013, 05:20 PM   #12
rbohm's Avatar
AFRs are good, as are edelbocks, world products windsor sr, canfields, brodex, in fact pretty much all the aftermarket heads are good ones, i would stay away from those made in china though, they can be very good or very bad. personally i would go with either the edelbrock or windsor sr heads.
Old 02-15-2013, 07:00 PM   #13
if your looking for good streetable power i would pick the afr 205. they are race heads but not too big to loose the reliable aspect.
Old 02-16-2013, 09:50 AM   #14
Ok thanks. That is exactly what I was thinking
Old 02-26-2013, 09:45 PM   #15
i went with HVH there is a picture in my "Newb" post.
Boarder32 is offline   Reply With Quote
06:18 PM
