Stainless steel brake lines - Mustang Evolution
Old 02-11-2013, 06:02 PM   #1
iStang65's Avatar
Region: Alaska
First to clear things up, when they say convert it to stainless steel, are they just speaking of the lines that run from the master cylinder to the rubber hose or does that rubber hose become stainless steel as well?
After that gets cleared, I would like to remove that rubber hose since its cracked all over but not sure on the steps. For I need to remove the brake fluid from the mast. Cyl so it doesn't spill out or leave the fluid. Then where do I start, the nut on the hub or where the hose meets the line on the frame bracket. Sorry again for all these simple minded questions, just figure this is the best way to learn, other then reading
iStang65 is offline   Reply With Quote
Old 02-11-2013, 06:06 PM   #2
1slosix's Avatar
they mean rubber hose to braided SS...i switched mine and love it
carving corners like a boss
Old 02-11-2013, 06:08 PM   #3
iStang65's Avatar
Region: Alaska
What benefits does it give you?
Old 02-11-2013, 06:09 PM   #4
1slosix's Avatar
i do alot of cornering so i've notice no spongy braking after the fluid gets hot...plus i don't worry about ever having rubber lines break down
Old 02-11-2013, 06:10 PM   #5
iStang65's Avatar
Region: Alaska
You drive it as a DD?
Old 02-11-2013, 06:11 PM   #6
1slosix's Avatar
of course
Old 02-11-2013, 06:12 PM   #7
iStang65's Avatar
Region: Alaska
of course
Nice. How much did the conversion run u
Old 02-11-2013, 06:13 PM   #8
1slosix's Avatar
around $150 for all 4 corners...bought mine from mossmuscle.com
Old 02-11-2013, 06:14 PM   #9
iStang65's Avatar
Region: Alaska
Thanks. One more question, when do most people change out the actually brake lines them selves
Old 02-11-2013, 07:08 PM   #10
1slosix's Avatar
most do it when they notice one collapsing or if their fluid is turning black (which usually means a line is breaking down)
Old 02-11-2013, 07:17 PM   #11
iStang65's Avatar
Region: Alaska
Ok I think mine should be ok for now. How do I close of the line when changing the rubber hose to the stainless steel ones
Old 02-11-2013, 07:39 PM   #12
1slosix's Avatar
honestly when i changed mine minimal fluid came out....you're gonna need to do a full bleeding anyways when you're all buttoned up so don't worry too much about fluid loss
Old 02-11-2013, 07:42 PM   #13
iStang65's Avatar
Region: Alaska
Ok thanks
---------- Post added at 05:42 PM ---------- Previous post was at 05:41 PM ----------
And did you use a flare wrench or just a regular one
Old 02-20-2013, 10:51 AM   #14
Tyoung68's Avatar
Flare!! Its a ***** if you round off the nut
Old 02-20-2013, 11:34 AM   #15
Don't let the master cylinder get completely empty, not fun to bleed it.
Old 02-20-2013, 12:00 PM   #16
Get a friend to help with the bleeding process and as said do NOT let the fluid get below the master cylinder line. Stainless steel braided lines are good, but for a daily probably wont really notice much. Good opportunity to change out to at least cobra brakes etc
Old 03-03-2013, 01:20 AM   #17
iStang65's Avatar
Region: Alaska
I've gotten all my front suspension taken off except one drum is still connected by the brake hose. Can't disconnect the brake line because the nut attaching it to the hose bracket is stripped so I was wondering if its ok to cut the steel brake line that goes to the master cylinder if I plan on replacing all the lines anyway?
Old 03-03-2013, 01:27 AM   #18
Tyoung68's Avatar
Cut away if you are replacing it it wont matter
Old 03-03-2013, 12:49 PM   #19
iStang65's Avatar
Region: Alaska
Do I need to drain the master cylinder prior to removing all the brake lines?
Old 03-03-2013, 01:16 PM   #20
Tyoung68's Avatar
It would be a good idea
Old 03-09-2013, 12:53 PM   #21
iStang65's Avatar
Region: Alaska
Anybody have any suggestions on how to remove a stripped nut on the brake hose before I cut it
Old 03-09-2013, 12:54 PM   #22
Tyoung68's Avatar
You could try to heat up what its screwed into and get a pair of vice grips
Old 03-09-2013, 12:56 PM   #23
iStang65's Avatar
Region: Alaska
Ill try a pair of vice grips. I never like using the torch around anything with fluid in it. Not sure how flammable brake fluid is
02:33 PM
