Whats this??? - Mustang Evolution
Old 02-17-2013, 10:52 AM   #1
iStang65's Avatar
Region: Alaska
Whats this???
Pulled upper control arms and these were attached to the bolts that bolts to the engine bay. Are they spacers?
iStang65 is offline   Reply With Quote
Old 02-17-2013, 10:56 AM   #2
Ubnbit's Avatar
Yes sir. Those are shims. You can buy them at any car parts place in any thickness you would like.
Old 02-17-2013, 12:32 PM   #3
Mlarv5's Avatar
If you are replacing the upper control arm or the bushing I would put the same one back in until you get an alignment, it will give the alignment place a starting point.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 02-17-2013, 02:05 PM   #4
rbohm's Avatar
as the others indicated they are alignment shims. you need to replace them as they came out of the car when you put the upper arms back in place to make sure your initial alignment setting is close enough to drive the car to the alignment shop, unless you have the required tools to align the front end yourself.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
Old 02-17-2013, 02:09 PM   #5
Ubnbit's Avatar
+1 very well said
Old 02-17-2013, 05:35 PM   #6
iStang65's Avatar
Region: Alaska
Thanks. Lesson learned the hard way I guess since they all just fell off and not sure what came off which side
Old 02-18-2013, 12:01 AM   #7
iStang65's Avatar
Region: Alaska
Should I be able to just stack them all and divide it in half and go off of that?
Old 02-18-2013, 09:51 AM   #8
rbohm's Avatar
nope, that wont get you even close. i think your best bet is going to be having the car towed to the alignment shop and let them do their magic. understand that this is a safety deal as well as a maintenance deal. if the suspension alignment is not at least close to spec, the car can be very uncontrollable when driving. it can be very squirrelly under braking, turning, and even just trying to go in a straight line.
Old 02-18-2013, 11:40 AM   #9
iStang65's Avatar
Region: Alaska
Thanks for the advice. It will be a while until the car leaves for an alignment anyway. Too much to do to it before hand
« Restomod | 5.0 Swap »
11:46 PM
