New edge motor - Mustang Evolution
Old 02-23-2013, 07:45 PM   #1
sam62893's Avatar
New edge motor
Just curious. Will a New Edge motor fit a 66 mustang body?
Old 02-23-2013, 09:10 PM   #2
BA68 mustang's Avatar
As in the transverse v6 In the crossover?
BA68 mustang is offline   Reply With Quote
Old 02-23-2013, 09:12 PM   #3
sam62893's Avatar
Yeah, I'm talking about the 3.8 liter V6 engines from mustangs '99 and '04. Specifically a '02 or '03 V6
Old 02-24-2013, 02:09 PM   #4
rbohm's Avatar
yes the 3.8 V6 will fit the 65-66 mustangs as nicely as the 289/302 does. understand you will have to make your own engine mounts, and you will have to figure a front sump oil pan or switch to front steer. and of course either use stock exhaust manifolds or custom headers. the trans will bolt up as they use the same 6 bolt bell housing pattern of the 6 bolt small blocks, but you will need the specific flexplate/flywheel from the V6.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
Old 02-24-2013, 02:17 PM   #5
sam62893's Avatar
I have the engine and transmission complete. So the transmission will bolt up fine just need to fabricate motor mounts. What about the exhaust? I have the exhaust manifolds from the same motor and also a set of the 97 manifolds. Can I just use those and get a new exhaust system and bolt it or weld it on?
Old 02-24-2013, 04:00 PM   #6
rbohm's Avatar
you should be able to use the trans mount, in fact you can use that to locate the engine and trans if you like, though it will sit a bit further forward than you might like, about an inch or so. and yes you can use the stock exhaust manifolds and fab a new exhaust system, no problem there.
Old 02-27-2013, 09:37 PM   #7
sam62893's Avatar
I think I might actually try this. Just gotta get the motor mount fabricated. What about all those extra sensors in the newer motor? The PATs system? The wiring harness?
Old 02-28-2013, 09:52 PM   #8
rbohm's Avatar
what i would do is get an aftermarket wiring harness and computer so you can use only the sensors you need. try painless wiring or ron francis.
new edge
« Brake Job | Engine »
03:24 AM
