Install an AC? - Mustang Evolution
Old 03-02-2013, 12:14 AM   #1
iStang65's Avatar
Region: Alaska
Install an AC?
The thought of adding one into the car sounds nice but what all is needed in doing so? I've found on CL a stock AC unit that came out of a 65 mustang but its just the console. What else would I need and how difficult is the installation?
iStang65 is offline   Reply With Quote
Old 03-02-2013, 05:07 AM   #2
Mlarv5's Avatar
You will need a compressor the hoses a new belt brackets to hold it up power from some place then someone to charge it.
There are after market kits with everything you will need to install one the install is not easy but I am sure it is very doable with normal hand tools and some time.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 03-02-2013, 07:12 AM   #3
05 MUSTANG GT's Avatar
this might help just to get a list going
1964, 1965, or 1966 Mustang Air Conditioning System | 64, 65, or 66 Ford Mustang AC
05 MUSTANG GT is offline   Reply With Quote
Old 03-02-2013, 09:53 AM   #4
rbohm's Avatar
Originally Posted by 05 MUSTANG GT View Post
nice link. installing a/c in a car, any car, that didnt have it to begin with is not that hard, but it is time consuming. in addition to installing the drive belt brackets, compressor, evaporator, condenser, receiver/drier, hoses, and all the other little bits and pieces, you still have to evacuate the system, leak check it, and then add the refrigerant. you need the proper gauges for the type of refrigerant you are going to use, and if you want R12 forget it unless you are certified by the EPA.
that said i dont want to discourage you from installing your own system, but definitely have a pro do the leak check and charge the system.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
05:40 AM
