Header problems - Mustang Evolution
Old 03-07-2013, 06:51 PM   #1
RWGmustang's Avatar
Header problems
Hi all
I'm working on my 67 mustang and I'm having trouble with headers. I'm in the middle of a motor swap going from the original 200 to a 351w. I decided to change to a cable clutch. The headers can not be too close to the cable. O and did i mention that it is a power steering car. I bought a pair of headman long tubes but it hit the cylinder for the power steering. I don't know what to do now. Any ideas?
RWGmustang is offline   Reply With Quote
Old 03-07-2013, 06:55 PM   #2
you mean its hitting the rack and pinion? how bad is it hitting? if its not much you can just dimple the headers with a ball pean hammer.
Old 03-07-2013, 07:04 PM   #3
RWGmustang's Avatar
It does not have rack and pinion. It is the power steering cylinder that is mounted horizontally from the frame to the linkage.
Old 03-07-2013, 07:07 PM   #4
Would you happen to have a picture handy. I'm just very curious to see how bad. Are you now considering stock exhaust manifold?
Port139 is offline   Reply With Quote
Old 03-07-2013, 07:07 PM   #5
RWGmustang's Avatar
The slave cylinder.
Old 03-07-2013, 07:11 PM   #6
If its not much you will just have to clearance them with a hammer like I suggested.
Old 03-07-2013, 07:20 PM   #7
RWGmustang's Avatar
I need about 2 inches. Short of having the header reworked i don't know what to.
Old 03-07-2013, 07:22 PM   #8
deadsp0t's Avatar
Could convert it to a manual rack..
That's unimpressive
Old 03-08-2013, 04:28 AM   #9
Have you checked for any after market ps slave brackets? Move the cylinder down an inch and then shim the motor up an inch off the mounts. There's your 2 inch clearance. Get a machine shop to fab an extra inch on the bracket too might be an option. Good luck.
Old 03-08-2013, 09:41 PM   #10
BA68 mustang's Avatar
Cj pony parts has a drop bracket for the slave cylinder it's like $20
BA68 mustang is offline   Reply With Quote
Old 03-08-2013, 09:53 PM   #11
RWGmustang's Avatar
Thanks everyone i ordered the bracket. That should solve all my issues with the headers.
05:06 PM
