Incorrect Dyno? - Mustang Evolution
Old 03-11-2013, 05:47 PM   #1
Chaunceton's Avatar
Region: Utah
Incorrect Dyno?
I just got back from getting the Mustang dyno'd and I'm not sure it was accurate. I knew the numbers would be a bit lower than expected, but not by too much. It dyno'd at 194hp. Much less than I expected. I thought stock 302's got around 225 hp stock.
It's a '66 GT coupe. The engine is a naturally aspirated rebuilt 302 from a '68 Galaxy 500. The engine has been ported, has headers, roller rockers, roller cam, 4 barrel 650 holly carb, K&N filters all around, msd ignition, and 3" flowmaster straight pipes all the way back. I thought the hp would be closer to 300.
The guy running the Dyno didn't seem to know what he was doing very well. He ran the Dyno when the car was in third gear, it registered 194hp and 245 ft/lbs of torque. Thoughts?
Chaunceton is offline   Reply With Quote
Old 03-11-2013, 11:34 PM   #2
Aggiesrok's Avatar
That sounds way off. With all that engine work, I would have guessed closer to 300 as well. Take it back have someone else do it.
Old 03-12-2013, 07:03 AM   #3
Chaunceton's Avatar
Region: Utah
Ok great. For a second I thought maybe I was going crazy. I wish I could go get it dyno'd somewhere else, but I live in a city in Utah where there aren't many dyno shops near. I think for now I'll need to be content with estimations.
Old 03-12-2013, 09:58 AM   #4
Aggiesrok's Avatar
I did a little research and i've seen several 289/302 in a fairly stock setup do 170-180 rwhp. But with your setup, heads, exhaust, cams, etc. I would expect closer to 250 or so. Did he adjust the timing or try to get any more out of it? Or just ran it and gave the ticket?
Old 03-12-2013, 10:51 AM   #5
Chaunceton's Avatar
Region: Utah
No adjustments at all, and the tach on the computer was registering slightly different than the tach on the mustang.
Old 03-12-2013, 11:16 AM   #6
Aggiesrok's Avatar
He didn't tune it, just dyno. Did you pay for a dyno tune or just to get the current number?
Old 03-12-2013, 11:18 AM   #7
Chaunceton's Avatar
Region: Utah
Just to get the current number. I think I've got the carb all dialed in. I was just curious as to what a dyno would tell me.
Old 03-12-2013, 01:15 PM   #8
dyno calibrations differ drastically from one to the next or one brand to another, no set way to get 100% accurate results, they are more for getting everything fine tuned than figuring out exact hp/tq
07:29 PM
