Coolant - Mustang Evolution
Old 04-05-2013, 07:43 PM   #1
iStang65's Avatar
Region: Alaska
Coolant
Is there any "BEST" coolant for a standard type radiator when refilling it?
iStang65 is offline   Reply With Quote
Old 04-05-2013, 08:14 PM   #2
Aggiesrok's Avatar
The best you can do is use distilled water when mixing 50/50. The minerals in regular water is what clogs it up with deposits.
Old 04-06-2013, 04:52 PM   #3
iStang65's Avatar
Region: Alaska
Can I use this and just pour it by itself into the radiator?
Old 04-06-2013, 04:57 PM   #4
Tyoung68's Avatar
No!! Its waayyyy cheaper to buy non mix and you can go get the water for a couple bucks
Old 04-06-2013, 04:59 PM   #5
iStang65's Avatar
Region: Alaska
Which coolant do you recommend
Old 04-06-2013, 07:13 PM   #6
Tyoung68's Avatar
Just get the 100% coolant that you mix to me coolant is coolant. So any brand will work. And as far as mixing it depending on where you live 50/50 will hold up to -32 and do mix it more than 75% coolant and 25% water. If you go higher than that the coolant will lose its ability to cool the engine down and you will run hotter
Old 04-06-2013, 07:18 PM   #7
iStang65's Avatar
Region: Alaska
Ok thanks for the tip.
04:46 AM
