Carb help? - Mustang Evolution
Old 04-13-2013, 09:09 PM   #1
iStang65's Avatar
Region: Alaska
Carb help?
Can someone walk me through the process on wiring an electric carb? Just converted from manual choke and not sure where to get the proper wire and where to run it
iStang65 is offline   Reply With Quote
Old 04-14-2013, 08:09 AM   #2
BA68 mustang's Avatar
I wired my electric choke from the back of the ignition switch
BA68 mustang is offline   Reply With Quote
Old 04-14-2013, 06:31 PM   #3
Commercial Member
matcox83's Avatar
That's a good place. You need 12 volts that is only hot when the switch is in "Run"
Old 04-14-2013, 06:34 PM   #4
iStang65's Avatar
Region: Alaska
Where did you pick up the wire for it and how exactly do you set it up
Old 04-15-2013, 06:52 PM   #5
I can't remember exactly I'll check tomorrow bit i think i tapped a jumper into one of the wires coming out of the switch( idk what one offhand ) ran it trough the firewall at the windshield wiper fluid hose hole and up to the choke
Old 04-19-2013, 06:26 PM   #6
Sorry I took so long, I usually go on the forum at night so I kept forgetting to check the next morning.... I tapped into the black wire with a dark green stripe and ran it through the windshield wiper fluid line hole, across under the cowl and up the intake manifold then I ran the ground for the choke to an intake bolt
Old 04-19-2013, 06:48 PM   #7
what is this on, if its a classic u should have a spot in the fuse panel
Mustaangsally is offline   Reply With Quote
Old 04-20-2013, 04:08 AM   #8
iStang65's Avatar
Region: Alaska
This is my fuse panel, so where's the best place on here to hook up the positive wire to?
Old 04-20-2013, 04:12 AM   #9
iStang65's Avatar
Region: Alaska
Also I was wondering what this was in the back of the manifold directly behind the carb?
Old 04-20-2013, 04:22 AM   #10
iStang65's Avatar
Region: Alaska
One more piece I'm not familiar with
Old 04-20-2013, 09:15 AM   #11
Commercial Member
matcox83's Avatar
First one is a vacuum tee. On your car, you only need manifold vacuum for an automatic transmission since you do not have a brake booster. The unused ports on the tee can just be capped. On cars with smog equipment, the others would be used. The other piece is nothing I'm familiar with. It looks like a hydraulic line??? What does it attach to on the other end? My guess is nothing, and it is probably not needed.
Old 04-20-2013, 10:19 AM   #12
iStang65's Avatar
Region: Alaska
Forgot to attached the picture of the fuse
Old 04-20-2013, 06:32 PM   #13
what the vacum port?
06:03 PM
