Engine Help - Mustang Evolution
Old 04-14-2013, 05:31 PM   #1
Engine Help
Hello I have a 1964 1/2 Mustang that I got as my first car and right now it has engine trouble. It over heats like crazy. Me and my dad are going to replace the engine since we already poured thousands into the engine we already have and still don't know what the problem is.
I would like something reasonably high powered, with kinda decent gas mileage but cheap to install.
Any recommendations?
I'm kinda a noob so try not to use complicated words and terms please.
From what I saw fuel injected looked nice but I do not know anything about it.
nyxservant is offline   Reply With Quote
Old 04-14-2013, 05:40 PM   #2
Aggiesrok's Avatar
What engine is in it now? You might be able to fix it and add some power for a lot less than starting over. No offense, but if you've poured tons into it and it still overheats, maybe you're not the best candidate for a new engine install.
Old 04-14-2013, 05:54 PM   #3
I won't be doing the installing. And I don't want to put more into the engine when it might not be worth investing in. I was thinking about buying a rebuilt engine and having someone install it.
---------- Post added at 06:54 PM ---------- Previous post was at 06:50 PM ----------
And it's a 1971 302 I believe
Old 04-14-2013, 05:57 PM   #4
Cool first car! If you have'nt already, take the radiator out and have it boiled.out at a.radiator shop. Or better yet, buy a new one. That is the main cause of overheating in older cars. Im kinda partial to the keep it simple theory. I'd just use the carburetor and get it running and drivable. Then decide what mods fit your needs and your wallet. What engine does your car have?
Old 04-14-2013, 06:00 PM   #5
DaBluedude's Avatar
The 302 is about the best engine you could have in there. If it's over heating, it's a coolant / radiator/ plumbing/ thermostat / pump problem. Having that diagnosed and fixed is going to be 10x cheaper than a new engine which still may not fix the problem.
2003 Mach 1
Old 04-14-2013, 06:07 PM   #6
I have replaced all of those.
Old 04-14-2013, 06:10 PM   #7
DaBluedude's Avatar
Then something wasn't done right, you have the wrong thermostat, or you have clogged or damaged coolant pathways in the engine. I seriously doubt the latter.
2003 Mach 1
Old 04-14-2013, 06:19 PM   #8
LukeRailey68's Avatar
What symptoms tell you it's overheating?
LukeRailey68 is offline   Reply With Quote
Old 04-14-2013, 06:32 PM   #9
Apparently metal shavings keep ending up in a radiator supposedly from the engine. And I thank you for the tips but I'm really just looking at a rebuilt motor for less than $1000
---------- Post added at 07:32 PM ---------- Previous post was at 07:28 PM ----------
And the new temperature gauge determining the temperature and removing the radiator cap and having water gush out like a fountain 100mph after driving the car for about 20 minutes.
Old 04-14-2013, 06:42 PM   #10
Commercial Member
matcox83's Avatar
Maybe what you are referring to as metal shavings is actually rust? If so, that can be ( and should have been) fixed with hot tanking the block and cleaning the passages before a rebuild. If you don't have the original engine, you are free to put what you want in. But, a 64 1/2 is one that most people would consider restoring to original due to the relative rarity. That said, you could still get a crate motor (already built, comes literally in a crate) 302 or 351. But you are looking at more like $3000.
Old 04-14-2013, 06:49 PM   #11
I wonder if, at some point, someone over did it with the stop-leak?
Old 04-14-2013, 07:07 PM   #12
I have no idea.
Old 04-14-2013, 07:13 PM   #13
I have no idea.
Old 04-14-2013, 07:13 PM   #14
Sometimes it's easier to just start fresh.
Old 04-14-2013, 07:52 PM   #15
Very much agreed
Old 04-14-2013, 09:38 PM   #16
Aggiesrok's Avatar
It's tough to go cheap and not do it yourself. I think your best bet is to tear your engine down to the block, leave the pistons in and crank in it. Take it to a engine machine shop and have it evaluated. If they say its not cracked, then have it machined and have them replace the pistons and machine the crank. Then you're starting with a good block, the 302 wasn't available in the 64 1/2.
Old 04-15-2013, 09:50 AM   #17
I will consider that. But the whole fuel injected thing. What's needed for that?
Old 04-15-2013, 10:29 AM   #18
Boomdizzle's Avatar
Honestly I'd get one of the budget short blocks from mustangs unlimited or 50resto. You an easily swap over all the heads intake and accessories from your old motor and will have a freshly rebuilt shortblock to start with. It sounds like something must be plugged up internally to be honest if you've already replaced everything else in the cooling department.
The budget short blocks are around $900-1k and have tree shipping to a commercial address.
Torque: It's like crack for your right foot
Boomdizzle is offline   Reply With Quote
Old 04-15-2013, 10:29 AM   #19
Aggiesrok's Avatar
They sell a kit that is integrated into a carburetor looking part, it has a fuel rail and uses injectors to introduce the fuel instead of jets, etc. It comes with a computer type module and a new fuel pump, since you will need a looped pressurized fuel system. Putting fuel injection on the original type carb engine, I don't think will get you a whole lot.
I don't know of a kit that uses an intake manifold type system.
If you are looking into installing an engine that already uses fuel injection, then you will need a computer to regulate fuel delivery as well as changing the fuel pump system. People have removed fuel injected engines from fox body's and other cars and installed them using all the original harnesses and computers. This will give you a more modern engine and some efficiencies, but it also gets a little more complicated to maintain as well.
Old 04-16-2013, 04:18 PM   #20
Stanglover1966's Avatar
If the engine is bored that could also cause it to heat up a little more. I'd add a slightly bigger radiator and change water pump and things if the such.
Stanglover1966 is offline   Reply With Quote
Old 04-20-2013, 06:28 AM   #21
Thanks. I'll look more into that.
---------- Post added at 07:28 AM ---------- Previous post was at 07:24 AM ----------
Also is there an easy way to just take a EFI motor and convert it to carb easily? Just wondering. I mean I understand there would be a lot to do if it were in a newer car but since I'd be putting it in a vintage one would there be much?
Old 04-21-2013, 08:22 AM   #22
Mlarv5's Avatar
I would double check the timing as well as the valves to see if they are to tight. A 302 was not an option in 64 1/2 they had a 289 now when you replaced the radiator did you get one for a V8 car?
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 04-21-2013, 09:05 AM   #23
Yes I got the biggest they had
Old 04-21-2013, 06:57 PM   #24
Mlarv5's Avatar
then check the timing and valves I have seen these cause overheating more then once
Old 04-21-2013, 09:50 PM   #25
Tyoung68's Avatar
You can just switch manifolds for efi to carb i think And if you are looking for more mpg then a v8 isnt a good idea haha all v8s arent going to be good on gas. There are mods that you can do thatll make the mpg improve. You can drop a 351 in for more power. And as far as the over heating problem have you done a coolant flush? My little 6 was over heatering and i just flushed it about 5 times. And you could have gotten a bad thermostat. Boil some water drop it in and see if it opens also make sure its the right way. And check the radiator car. If it isnt sealing properly then that can cause it to over heat. When the cooling system is under pressure it raises the boiling point also can you post a picture of the metal shavings? Maybe you have a problem with your water pump it seems like there must be a cheaper way to fix it than to drop a mew motor i.
Old 04-22-2013, 02:56 AM   #26
tc x 4's Avatar
Sounds like your best option. Jasper engines are reasonable. The cooling system needs gone through, or you'll be swapping engines again.
Old 04-22-2013, 03:07 AM   #27
tc x 4's Avatar
If your sure the radiator is good, it leaves me to believe you have a cracked head. Time for an upgrade and make that sucker really bad.
---------- Post added at 04:07 AM ---------- Previous post was at 04:04 AM ----------
Or blown head gasket.
Old 05-01-2013, 10:05 AM   #28
We removed and inspected the engine. Turns out one thing was that they over torqued the heads basically crushing the gaskets making them useless. So we are going to do it right and hope it works.
04:10 PM
