Engine shut off - Mustang Evolution
Old 04-25-2013, 08:24 PM   #1
iStang65's Avatar
Region: Alaska
Engine shut off
Car turns on no problem for the most part. Have to give it a little gas but then fires right up. Runs for about 45 secs to a little over a minute before shutting itself off and not sure why. Can it be the fuel filter needs to be replaced? Could it also be the weather? It's highs of mid 40s right now in Alaska. Have an electric choke Holley, donno if that helps.
iStang65 is offline   Reply With Quote
Old 04-25-2013, 09:14 PM   #2
iStang65's Avatar
Region: Alaska
I have a feeling that the cars just not warm enough but do I just keep pumpin the gas? First time dealing with electric choke and I've owed a carbureted bike before but it had manual operation of the choke so I was able to control the opening of the choke during cold weather start ups. Not sure how to operate the electric choke for these cold days
Old 04-26-2013, 08:21 AM   #3
Mlarv5's Avatar
It does sound like a fuel problem I would check fuel pump and filter first. I can't think of a reason the choke would cause this problem unless the smoke was coming out almost black which would mean it was to much gas.
To operate the choke if it is wired correct you set it and forget it. As the coil warms up it changes the choke position until there is no more choke.
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 04-26-2013, 05:22 PM   #4
iStang65's Avatar
Region: Alaska
Alright. I look into the filter and pump and see if that fixes it.
Also spoke with a buddy and he said the choke plate could be sticking from sitting over the winter. Suggested I remove the air cleaner and start up the car and see if the choke plate slowly closes as the car warms up and if it does then it rules out the choke being a problem
Old 04-26-2013, 07:42 PM   #5
iStang65's Avatar
Region: Alaska
Definitely need help now. It started up fine this attempt and didn't shut off on me (thank goodness) but my problem now is that my choke plate stays wide open. Isn't it suppose to slowly close itself as the engine gets warmer? Here's a photo of it while the car was running for about 5 min
Old 04-26-2013, 08:52 PM   #6
Commercial Member
matcox83's Avatar
No, it closes when cold. When the intake manifd is cold, the fuel actually condenses back and sort of sticks to the manifold, that's why the choke is closed when cold, it creates a much richer fuel mixture so the car will run. When it heats up, the atomized fuel makes it to the cylinder easier, so the choke opens to allow a leaner mixture. Sounds like your choke is working if it is blocked off when cold, then slowly opens.
Old 04-26-2013, 09:42 PM   #7
iStang65's Avatar
Region: Alaska
Looks like I had it backwards. Thanks for clearing that up for me. Makes since now
05:04 AM
