Painless wiring harness - Mustang Evolution
Old 04-30-2013, 10:14 PM   #1
iStang65's Avatar
Region: Alaska
Anyone have it in your mustang? If so has anyone had to replace the big fuse from the box that goes to the solenoid and starter?
iStang65 is offline   Reply With Quote
Old 05-01-2013, 03:58 PM   #2
LukeRailey68's Avatar
I have it but never had to replace that fuse. You're talking about the 70 right? It's huge. Is your's blown?
LukeRailey68 is offline   Reply With Quote
Old 05-01-2013, 06:09 PM   #3
iStang65's Avatar
Region: Alaska
It's for my 68 fastback but it has a 50amp fuse but yeah it's the big one and yeah it's blown
Old 05-02-2013, 12:43 AM   #4
Tyoung68's Avatar
I have one but no i didnt why do you ask about it?
Old 05-02-2013, 07:54 PM   #5
iStang65's Avatar
Region: Alaska
Was wondering where to get the fuse because its cut differently then your regular fuses and almost all the shops in my area didn't have that type but I finally found one so my 68 is back up and running
Old 05-02-2013, 07:57 PM   #6
Looks good!
Old 05-02-2013, 08:00 PM   #7
iStang65's Avatar
Region: Alaska
Looks good!
Thanks. Now that I have this one driving on the roads, need to turn my attention to restoring the 65 coupe
Old 05-02-2013, 09:07 PM   #8
Commercial Member
matcox83's Avatar
Did you find the short to ground? Fuses don't blow for no reason. If you didn't find the short, you ought to get another spare fuse.
Old 05-02-2013, 09:08 PM   #9
iStang65's Avatar
Region: Alaska
Please elaborate short to ground
Old 05-02-2013, 11:04 PM   #10
Aggiesrok's Avatar
Metal body of the car is ground or negative. A positive wire from the battery goes to a light bulb them to ground and lights up. If it has a knick in the positive wire and goes to ground or the body before the light bulb it's shortened the distance to ground and called a short circuit.
In the case of a fused wire, it blows the fuse, thus saving the remainder if the circuit.
So he's saying you need to find what caused the fuse to be shorted and blow. Or else buy an extra because it'll blow again eventually.
01:42 PM
