1965 turnover - Mustang Evolution
Old 05-02-2013, 08:04 AM   #1
1965 turnover
I have a 1965 coupe and it will not start. I drove it last summer and got to my destination but the engine would not turn off even when I removed the key. It fried the wires in the process. I have replaced the wiring harness, starter, voltage regulator, and the cellinoid. Now it will turn over but not star and will continue to turn over when I remove the key. Does anyone have any suggestions? I am stuck on this.
Kornohalic is offline   Reply With Quote
Old 05-02-2013, 10:19 AM   #2
Tyoung68's Avatar
So itll spin but not start?
Old 05-02-2013, 10:38 AM   #3
That is correct, and it will not stop spinning. I have to disconnect the battery.
Old 05-02-2013, 10:59 AM   #4
Tyoung68's Avatar
Sounds like you have the solenoid wired wrong or its bad and as far as your motor is there good gas in it?
Old 05-02-2013, 11:07 AM   #5
Mlarv5's Avatar
Lets start at square one do you have a multimeter and know how to use it? If so you can disconnect the starter and work backwards from there to see where you are getting the voltage to turn it.
Unplug the two connectors going into the front of the solenoid and see if one or both of them have any voltage on them.
If you unplug both wires does the engine still turn over on its own?
This seems to be pointing at an ignition switch being bad
Here is a wiring diagram for the ignition this is for a 1967 just do a search for your 1965 and you can find the same images. I guess I have to stop reading to fast cause I just make up dates and see things that are not there.
67MustangEngineWiring.jpg Photo by mil1ion | Photobucket
http://www.bing.com/images/search?q=...electedIndex=3
http://www.bing.com/images/search?q=...electedIndex=7
http://www.bing.com/images/search?q=...lectedIndex=12
1968 Coupe <53000 miles on her 289 came off the line Jan 21st 1968. I bought it in 1983
2013 Shelby GT500 Born 12/06/2012 number 439 of 530 in DIB and 1 of 9 with Red Stripes over the top and on the seats
Mlarv5 is offline   Reply With Quote
Old 06-15-2013, 05:08 PM   #6
How could I check this?
Old 06-15-2013, 07:21 PM   #7
Tyoung68's Avatar
Well the solenoid had a little paddle in it there and when you turn the key it gets pulled down but not release so it could just be a bad solenoid or its wired wrong there should be an i and s on there search the web or what wires go where
---------- Post added at 06:21 PM ---------- Previous post was at 06:18 PM ----------
Or you can un do the wires from the harness so its just connected to the bat and take a screw driver and touch the hot side to the closest terminal and you can start it from that way you can test if its the wring or the solenoid
07:37 PM
