Sqeaky mounts - Mustang Evolution
Old 05-05-2013, 08:08 PM   #1
67fastbackguy's Avatar
Sqeaky mounts
Any suggestions for something to spray car undercarriage joints that squeak with anything other than WD-40 which washes off?
67fastbackguy is offline   Reply With Quote
Old 05-06-2013, 08:04 AM   #2
Commercial Member
matcox83's Avatar
The constant squeak usually comes from the lower spring perch. The best thing to do is replace them. It's not a bad job if you know how to get the springs out in a safe manner. I don't know of any quick fix that works.
Old 05-06-2013, 09:32 AM   #3
Aggiesrok's Avatar
If it's the spring perch (like matcox suggested), you can get poly bushings for it and then use a lithium based grease on it, not petroleum based. Also could be where the lower control arms bolts to the frame, that's a non grease zert joint. You could put polys there as well, but if you replace those you'll have to mark carefully the location or get an alignment after.
Old 05-06-2013, 10:36 AM   #4
Commercial Member
matcox83's Avatar
That's right. There are aftermarket improvements for all the suspension parts.
Old 05-06-2013, 10:02 PM   #5
Cool, thanks for the input!
Old 05-10-2013, 01:59 PM   #6
rbohm's Avatar
you can also get roller spring perches as well for not too much more money, and they work better than any with a rubber or urethane bushing.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
08:22 PM
