What to do next? - Mustang Evolution
Old 05-07-2013, 09:02 PM   #1
Tyoung68's Avatar
What to do next?
So im not sure what to do next. I have a 68 mustang im going for a resto mod look im going to hold off on the motor for now till i can save up for a good one. And i have upgraded brakes so what else should i do to the suspension? I have a bump steer kit and shelby drop and its lowered in the front. Any suggestions would be greatly helpfull!!
Old 05-10-2013, 04:48 AM   #2
BA68 mustang's Avatar
Sway bars front and rear and springs? Have you played with the rear end yet... Maybe a diff
BA68 mustang is offline   Reply With Quote
Old 05-10-2013, 10:59 AM   #3
BigpapaDean's Avatar
What I'm doing right now is: panhard bar, front + rear sway bars, traction bars, frame connectors and the lowering leaf springs. Just the panhard bar itself will be like night and day!
In a year or two....ill prob add some coil overs with original placement (keep costs down).
BigpapaDean is offline   Reply With Quote
Old 05-10-2013, 01:57 PM   #4
rbohm's Avatar
what front springs and front sway bar you go with depends on what motor you are going to use. if you plan on using a 289/302/5.0 then use either the 480lb rate or the 540lb rate springs in front with a one inch front sway bar. if you are going to use a 351w or 351c engine, then go with either the 540lb rate or 620lb rate from springs and one inch front sway bar. if you are going with a nig block then you want to go with a 700lb rate front spring with a 1 1/8 inch front sway bar. rear springs should be either the 4 1/2 or 5 leaf springs with a 200ib rate, and the rear sway bar should be a 3/4 inch bar. if you have the money, you might consider stepping up to a fiberglass leaf spring from flex-i-form. here is their website-http://flex-form.com/products.asp
i would upgrade the lower control arms to ones that use a spherical bearing, and add in adjustable strut rods, both of these can be obtained from opentracker racing products. this is their website Opentracker Racing Products.
in the rear i would add some kind of traction bar, the two best are the shelby under ride bars or a set of cal tracs. for socks the best are konis, but you can also use KYBs for a budget build.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
Old 05-11-2013, 01:54 AM   #5
Tyoung68's Avatar
I was looking at a 4 link for my rear end from steet or track but can do that till my tires wear out and i was looking at the springs that get stiffer as it compresses. I was also looking into making my own LCA an strut bars i have access to the tools to make them properly
---------- Post added at 12:54 AM ---------- Previous post was at 12:51 AM ----------
I was also looking at sway bars i do plan on going to v8 would it make a difference iv i got v8 suspension parts not even tho i have a l6? Im going to replace the quarter and rear taillight panel and a few other body mods an then its all to making it handle like its on rails
Old 05-11-2013, 11:45 AM   #6
rbohm's Avatar
the only suspension components that are different between the l6 and V8 cars in 66 are the springs and the spindles.
Old 05-11-2013, 11:47 AM   #7
Tyoung68's Avatar
I have a 68 haha i know my name is confusing i realized that after i made it
Old 05-11-2013, 03:57 PM   #8
rbohm's Avatar
alright smartass the only thing different is the springs.(stupid young whippersnappers!!)
Old 05-11-2013, 04:22 PM   #9
Tyoung68's Avatar
Haha :p well thats good then ill get everything or my suspension stuff except springs
01:48 AM
