Name this hose! - Mustang Evolution
Old 05-11-2013, 10:01 PM   #1
Bucket's Avatar
Name this hose!
I recently changed the u-joints in my mustang. After I did. I started it up and I drove it forward about 5 feet, it felt like it popped out of gear and it rolled backwards ( slight hill) the transmission fluid looks okay. When I looked at the engine I saw a hose popped off and I can't find it in my chiton. Any ideas? Please and thank you anything helps.
Bucket is offline   Reply With Quote
Old 05-12-2013, 07:27 AM   #2
Commercial Member
matcox83's Avatar
What year 6 cylinder is this? That fitting was on early ones, but I don't think it was there from 1966 on. I'll look it up when I get home, but I don't think it is the source of your problem.
Old 05-12-2013, 08:59 AM   #3
rbohm's Avatar
that looks like a road draft tube for venting the crankcase.
my mind is aglow with whirling transient nodes of thought careening through a cosmic vapor of invention.
rbohm is offline   Reply With Quote
Old 05-12-2013, 09:38 AM   #4
Commercial Member
matcox83's Avatar
That's what I thought, but I wanted to confirm.
Old 05-12-2013, 12:44 PM   #5
Bucket's Avatar
I believe it's a 66, that's the year anyways and it's a straight six. If that's not the problem what do u guys think?
Old 05-12-2013, 01:56 PM   #6
Commercial Member
matcox83's Avatar
When you say "popped out of gear" I assume its a manual, or is it automatic? Are your new u joints still intact?
Old 05-12-2013, 02:10 PM   #7
Commercial Member
matcox83's Avatar
And I am very confident saying they did not have a road draft tube in 1966. My guess is the engine was swapped at some point.
Old 05-12-2013, 03:51 PM   #8
rbohm's Avatar
correct.
as for the trans problem, check the vacuum tube that runs from the modulator valve to the engine, chances are it is disconnected or the modulator is bad.
Old 05-12-2013, 05:19 PM   #9
Bucket's Avatar
It is an automatic and I just installed new u joints
Old 05-15-2013, 06:27 AM   #10
Commercial Member
matcox83's Avatar
Any updates? Was the vacuum modulator hooked up and OK?
03:44 PM
